Please Help Car wont start and have searched but no joy ????
APB
Hello problem after problem my car wont start no spark getting to the plugs ??? it was running fine then started to splutter intermit then died on my, started back up and idle perfect but as soon as you try to pull off again the engine and Traction lights flicker while the car splutters drop of the accelerator and cars idles fine again then it cleared drove fine for about half hour got her home went to go back out and it started then died started then died and now wont start at all checked plugs and seems no spark is getting to them ????? what could it be ??
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Is you car remapped?
I had exactly the same problem with mine after remap, it was due to the ECU being opened and not sealed properly, hence filling with water.
Do you have VAGCOM?
APB
Hello
No vag com unfortunately matey ??? def no spark getting to all four coil packs ?? What shall i do ??
APB
No Start
Where is the ECU on these cars mate can i check or do anythink ?? only had the car a short time and its my first Ibiza Cupra so not sure of part locations etc ?
APB
just had a quick look and cant seem to see that is been wet recently looks dry as can be ?? Anythink else it can be ??
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Try a known good coil pack, see if you get a spark, but to be honest i have never known of 4 coil packs going at the same time, check all the fuses in the fuse box under the steering wheel.
Failing all that i reckon your ECU might have gone down,
Hope its not though.
APB
is there a ignition relay i could check whats the big fuses above the little onmes for underneath the steering wheel can i take the ecu apart and check inside or will this need to be done by an expert where do i need to go from here ??
APB
Ok update electrical tested the four wires going onto the coilpak unclipped the clip going into the coil pack so i have 1 power 2 earths but theres a black and blue wire that seems to be doing nothink what should this be ??
