jonnie5
Seat Leon FR+
Mar 14, 2007
342
Rosyth
When I replece the rear wiper next week when the parts arive, upgrading to the fabia system will this mean that the washer jet will spray more than an inch up the window?:shrug:
The fabia wiper does not replace the washer jet, only the wiper arm, wiper and cover.
So unfortunately your spray will be the same.....
Great mod though, fitted mine this week.
It makes much better use of the spray though, so don't worry too much. It's not just a cosmetic mod, it really does function better too!
You should be able to adjust the washer jet with the use of either a small needle or pin, and poke it in the end of the jet and wiggle it around. You will only need to adjust it around alittle bit to get the aim right.
I used it once and luckily its been sunny all week as I've tried to avoid using it its that bad. Wipers on the front aren't to bad just the jets dont spray the just have a single puny jet.:think: [:@] :cry: :(
yep
unfortunately the jet still goes with the same power as a smurf spunking
i just dont use mine
use the rain!
