fault code(17748 Camshaft/Crankshaft Position Sensors (B2) - Out of Sequence A)
wazo
293
lincoln
Visit site
either that or the iming belt has slipped a notch, have read of this before and subsequently the slipping of the belt has blown the engine up id get it checked out if i were you
cupra_steve
Do you have a alter ego ?
Oct 21, 2006
16
Huddersfield
Ye definatly get that looked at mate ! If you have had a belt fitted it int too bad, you just have to get it refitted and the timing sorted ! Otherwise it sounds like the timing has jumped ! Possibly down to a dodgy tensioner ? or water pump pully ? either way there's nothing stopping it from jumping again !
Nov 2, 2004
9,335
South Wales
I've got this fault code now, slightly different....
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-10 - - - Intermittent
Had the cambelt and roller replaced last week and i'm thinking it hasnt been timed properly or could it be something else?
YerMother
comes and goes
Sep 22, 2004
1,461
East Midlands Drives: Scirocco GT
It's intermitent! Clear it see if it comes back! i had that one ages ago, haven't had it since :shrug:
Nov 2, 2004
9,335
South Wales
I cleared it last week after i had it done. I'l let the garage know, but in the meantime i'll keep and eye on it.
Where are these sensors? Any chance they are a push plug type that might have been a little lose or is it completely different?
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
Possible Causes
Timing Belt incorrectly installed
Camshaft Position Sensor (G40) faulty
Engine Speed Sensor (G28) faulty
[edit]
Possible Solutions
Check Timing Belt installation
Check/Replace Camshaft Position Sensor (G40)
Check/Replace Engine Speed Sensor (G28)
Nov 2, 2004
9,335
South Wales
Not yet. Gonna be lookin at the timing belt tomorrow to see if its out. I'm 99% sure it is now. My rr graph suggest its pulling back at 5k which sounds about right for retarded timing out a tooth etc..
Have you just had your timing belt done?
petermunns
Ummm my car does faulter abit at 5K notice it in 3rd the most and long motor way trips... :S
Yep just had my time belt done...but they say its out by half a tooth each way...??
Dec 3, 2007
2,475
cardiff
but i have this code and i haven't had timing belt done. This was done 10.000 miles ago. Haven't done anything to the car. Is it that easy for belt to slip?
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
sorry to bring up an old topic, but i have had this fault on my car ages. did you lot get it fixed??
i really dont think its my timing belt, due to the fact that my car is running perfectly fine, and not pulling back at high revs. idles fine, and good MPG.
anyway, i just need to know the position of sensors G28/G40. crankshaft and engine speed sensors
P1340 - 35-00 - -
