decat pipe
turbo017
107
SLOUGH
sorry know there is another thread on this topic i'm looking to decat my mk3 ibiza but just wondering what the performance is like is it better than a 100 cell cat on the car any help would be good its due in after i've done it for a apr stage 2 will it cause any problem ie lam sensor or maf or any other problems
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
it'll be less restrictive but not a great deal of performance difference between the two
also you need the post cat 02 sensor disabled as well as a friendly mot garage
turbo017
107
SLOUGH
garage all good but i dont understand about the lam sensor what i would need to do with them as the decat pipe alloews for them to fit in
acidstrato
Dec 9, 2004
5,942
the lambda 02 sensor will need to be refitted (no problem) but the values it will receive will be out of the norm range so engine management will kick up a fuss
but a remap like revo stage 2 or custom code can ignore it so it wouldnt cause any problems
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
IIRC you'll get faults codes even if both sensors are in place as they will tell the ECU that your exhaust gasses have NOT been through a CAT. The only hope you may have is finding a remap that eliminates the use of the 2nd probe, to fool the ECU. (will have to ask APR)
TBH your better off getting a race CAT, more money i know but a deCAT will NOT get you through an MOT and its a right pig of a job to fit, so prepping for an MOT would be a pain in the arse. Not to mention the fact that you'll see similar gains with a race CAT as you will with a deCAT, just without the fault codes/engine light.
godzuki
Mk2 cupra & golf mk2 20vt
Sep 11, 2006
231
Newcastle upon tyne
are you saying because of the year of the car.......it doesnt need a cat.
Yeah! Breaker is right!
I understand about the 2nd lambda probe & will need a revo stge2 to stop any ecu problems (unless i go megasquirt)
I will run it with the cat to begin with though,then when i put the ko3s on and go for a remap i'd like to junk it :D
I had heard of moving the 2nd probe further out of the way to fool the sniffer sensing less of the emissions,but i'm not sure about this as the gasses would be under pressure & it could be a myth (twas on an american site iirc) & i'm no expert.
godzuki
Sep 11, 2006
231
Newcastle upon tyne
if its going into a mk2 golf then you'll likely be having a custom downpipe made...so just stick a race cat on that and job done
Well i'm pretty confident the ibiza DP will fit straight in ;) qpeng do a pipe for them for £200 but theres a 2 month waiting list for them plus the cost of a race cat :(
Mind you, i hadn't thought of a race cat so mabe its something i should look into as it would solve a few problems and denote the need for a stage 2 which is not exactly cheap,so cheer's for the input :clap:
godzuki
Sep 11, 2006
231
Newcastle upon tyne
Yeah i know what you mean,however i think it fits straight in a mk2 ibiza which is basicly the same as a mk2 golf,i'm also gonna slot it in using the std subframe (mk3 golf) too so its gonna be a propper "parts bin" special lol!
Sorry for going off topic :redface:
Am i right in thinking lambda's work by sending "X" volts back to th ECU? if so could this be intersepted so to speak mabe using a resistor to give the correct number the ecu requires? i'm not good with electronics but it could be a starting point if someone were wanting to look into it :think:
