Body Work Diy
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Im thinking about this for a few days. my leons comes with front and and rear bumper strips (black ones).
Im thinking if i remove the strips in the front and rear bumper, then fill the gaps and respray!Leaving the door ones just spray them
Has any one dones this before? my front bumper has been upgraded,
Any suggestions? soon the alloys will upgraded after that
Spin
seat****sweden.se
Dec 14, 2001
150
Sweden
www.klucken.se
A bit to much work I think.
Just get them resprayed in the same red as the car.
(and there is a bolt under each bumperstrip to hold the front)
Big_daddy
Oct 20, 2006
3,930
Brummy
im thinking of taking it bodyshop who will do it for me, so how do front and rear bumper strip come off?
can this easily be fillared up?
Leon.SJ
Naturally aspirated...
Oct 16, 2006
150
South Bucks.
I've been thinking about doing the same thing - my Leon's even the same colour as yours! I think it would look good, but didn't know about the bolts behind the strips... might have to pull the strips off to see where exactly they are... :think:
Nov 27, 2006
1,204
www.cardomain.com
They just prise out. One of the front bumper mounting points is underneath the front one at each side.
Really ?
That makes my bodyshop guy a sneaky bastid :blink:
Or he just didn't think it was worth mentioning :p
I got the corner strips removed and filled and never had any problems with the bumper coming loose (and it was off and on again at least twice)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
leave the screws out - the centre guides and other mounts are usually tough enough to cope
bin the door mouldings to oor they'll look odd
must admit i like the look on the toledo - V.smooth
Nov 27, 2006
1,204
www.cardomain.com
Pegged through square holes cut into the outer doorskin :-(
I'd like to get mine filled and sprayed at some point ... in a sick kinda way it would be the silver lining should anyone run a key down the side of it - hopefully never come to this though
IBD
Here Again!
Jan 16, 2006
254
North West
Great minds think alike and all, its one of my plans too!
I thought about leaving the screws out too as LCR's dont have screws through the bumper I presumed it would be ok.
I am thinking of getting a spare bumper to do the work on the take it for paint.
The hole left is quite deep though so is it a case of plastic welding ?
How do you plastic weld?
Nov 27, 2006
1,204
www.cardomain.com
Just filler - well keyed in and left proud so it can be shaped back when it's dry
The back bumper's full of the stuff :p
Plastic welding's not much cop for exterior parts as I understand it, cos you still need to fill/smooth any gaps afterwards and then you're just left with thin slivers of filler that are more likely to crack and flake off :(
