RAF
Compresser efficiency from inefficien to ultra efficient will only vary from low 60's to mid 70's percent, so your actual charge temp will only vary by a few degrees peak.
Same thing applies to intercoolers, so unless you have a masively undersized one, (or a side mount), it'll make little or no difference.
If you really want to bring your charge temps down, use water injection.
The only interesting thing you'll find from a compresser map is peak flow, and peak pressure ratio.
Did you ever log your charge temps with your FMIC Wilko?
Aren't you meant to be in Brazil?
Raf
how much room was there between compressor housing and cyl head/block john on your 18G on Jabba mani?
none.
A little grinder action was necessary to the head casting, and a small amount on the block to make it fit.
If I did it again, I'd make a 5mm laser cut stainless spacer to fit between the head and the jabba mani, to space it from the block/head, and maybe another between mani and turbo.
Longer studs would be needed to.
they still had to grind some out of the transfer box to get it to fit billMakes the Owens one look like one of the few upgrades possible on an underslung mani like JS.
raf just get it fitted and mapped and leave it to the experts to worry about the tech stuffthe vf34 is a tried and tested turbo so dont worry about it
they still had to grind some out of the transfer box to get it to fit bill![]()
