anyone else here experiencing wear problems on GSD3 Eagle F1's?
Not wear as in wear rate, but wear pattern.
If you can imagine running your hand over the top of the tyre on the edge (inner and outer) the wear pattern is wavey, kinda 50p shaped wear.
result of which is a wheel bearing rumbling/resonance. There can be loadsa tread on it still, but this odd wear pattern.
Happened twice to a friend with new Mk5 golf(s). did it on his PD140 and now doing it on his new PD170 GT . Mostly happening on the rear tyres.
Had a call from someone else this morning suspecting suspension/damper wear and continued to then describe the exact same wear patterns as my m8. His were 2 brand new MK5 Golfs, and this other is a MK3 Cupra Ibiza. Rear tyres on both of them, and same wear pattern.
Seems to me to be a tyre construction issue..
anyone else seen this and maybe thought "ah, suspension problem" where it might have been a tyre problem.
