Koni FSD's and standard springs
CT Aviation
Hi All,
I am just about to order a set of FSD's and intend fitting them with the standard springs as I do not want to loose any ground clearance. my question is, has any one any experience of the FSD's with standard springs ? is the ride improved much ?
Chris
Eddy Gein
70
Id like to know what would happen when you use fsd's and oe springs aswell. Surely just improved comfort and handeling? Im putting 19s on when i get it and have the aero kit aswell so dont want to go to low as to rip bumpers off on speed bumps.
sven7
88
North West
I had the FSD's fitted with the Eibach Springs.
I've had for these for sometime now and have never had any issues with speed bumps even with passengers in the car.
The link is attached where you can see some pictues, I would say that it is about 15mm lower than standard.
I feel the ride is better than before (less bouncy) and the handling is excellent, its got to the stage where I want to drive a standard FR again to compare - after time you forget what it was orginally like.
http://www.seatcupra.net/forums/showthread.php?t=105699
Eddy Gein
70
OH YES!:clap: thanks for the link mate that setup looks great and youv put my mind at ease. Thats definatly the kit im going to go for now, eibachs and fsd's:) .
Cheers.
CT Aviation
Well I fitted the FSD's this afternoon and whilst i have only given it a quick thrash around the block the difference is very noticeable. No more crashing from bump to bump (I even found myself looking for potholes to prove it was better)
I have retained the OE springs and the ride is greatly improved even on the 18's. If only Seat fitted these as standard . well pleased.
Chris
EdwardNR
Excellent news!
As soon as I can afford it I'll be doing the same thing I think, if you get a chance please put some further thoughts once you have driven some more miles.
CT Aviation
Edd, just been out for a blag with the wife as judge and even she commented on the noticeable change in ride comfort.
If you want to see for yourself, as you are not far from me, let me know and you can experience it for yourself.
I think the sport pack on the Stylance is the same set up as the FR so it would be good to try them back to back asit were to make difinitive comparisons.
Any one want to buy a set of FR standard dampers (55 mm fronts), only 1 month old and 20000 miles ?
Chris
EdwardNR
Cheers Chris, I may take you up on that sometime.
Glad the ride's better, hope it doesn't knacker your back as much now!
CT Aviation
Damm too many zero's now up to 2500 miles.
Edd, just PM me or drop me an email to [email protected] when you want to try the Koni's, it would be good to compare rides back to back as it were.
Chris
k4ith
Goodson!
Sep 3, 2006
746
West Lothian
yahoo, got my Koni FSD & Eibach pro kit fitted today, what a difference, i have been out all afternoon in the country side belting it , oh the joys of good suspension, even in town over cobbles( which there is loads in edinburgh) its been a joy.you nottice a diff in height @ the front but the back has only gone down about 10mm, will check once it settles. best thing ive bought since i remapped my Golf!
sven7
88
North West
Makes heck of a difference doesn't it - best thing I did too. Can't recall the old suspension setup now but I thought it was a lot better than standard.
simon34
smoooooooth
May 2, 2006
535
northampton
Good to hear :)
you going to put some pics up
Rob GTI
544
South Wales
Chris
Whats the handling like on the new shocks with OE springs? I am seriously consdering these are I am get quite fed up of the ride quality (I can feel my pea sized brain rattling around in my head sometimes, I'm sure it may cause some long tern effects like makign me speeel things wronlgly and my gramar worser)
k4ith
Goodson!
Sep 3, 2006
746
West Lothian
car as it was standard
car with Koni FSD & Eibach pro kit.
there doesnt look much diff but its has dropped the car with the new springs as its now harder to get the sponge into clean the arches
Rob GTI
544
South Wales
So is handling and ride improved?? How much was it all fitted mate if you don't mind me asking???
k4ith
Goodson!
Sep 3, 2006
746
West Lothian
the handling was fine it was the ride comfort that finally wore me down, it was ok on motorways etc but in town over bumps it was annoying.Now its far better.The FSD's & eibach pro kit plus fitting and 4wheel alignment came to £750.
CT Aviation
I am happy too with just the Koni's. Only issue is why didn't I choose silver ! your cars look great guys, mine looks stunning in black after a few hours cleaning but it don't last long (the wife insisted on black)
Handling seems similar but with a little more body roll on long fast corners, otherwise still as good and I think improved traction on rough surfaces and rapid direction changes (throwing it into a corner hard)
chris
k4ith
Goodson!
Sep 3, 2006
746
West Lothian
for me i think it may have saved me selling the car, i didn't like a few things but has restored my faith in the car, wish i had got the tfsi still.but once the speakers are done the car should be as i want it.
