zilspeed
First of all hello to all. Never posted on here before.
SWMBO has a 2000 W reg. Ibiza 1.4 with a cable clutch. The pedal box had gradually cracked and bent - enough for the clutch to stop working properly.
To be honest, I didn't fancy removing the box etc and fitting a new one. It's a design fault and the new one will fail again.
The fix was very very easy.
Remove panels under dash to allow access to pedal box area.
In the engine bay, remove the two panels at the bottom of the screen.
(This is where the clutch cable goes through the bulkhead.)
Back in the footwell, locate the steel pressing that the clutch cable locates into from above. This is what we need to secure.
You now need a 3mm pilot drill, a 6mm drill and an M6 bolt, nut and washers.
Pilot drill from the footwell up through the aforementioned bracket into the bulkhead and through the bulkhead. Insert the bolt from underneath and the nut from above with washers at either end.
**top tip**
You don't need four hands to do this. All you do is jam the bolt in from below using a handle from a trolley jack or similar from the floor of the car up.
Tighten it all up, reassemble the various bits of trim and you're done. Takes an hour from start to finish and your clutch is back to normal.
Got to be easier than fitting a new pedal box.
**top tip**
