The most notable of these are the bi-xenon headlights with Advanced Front Lighting System (AFS). This system blends the superior luminous power and quality that bi-xenon headlights are renowned for, with all of the benefits of AFS intelligent control.
The AFS system uses the information gleaned from various rotational and speed sensors in the vehicle to adjust the direction of the beam of light emitted by the headlights, resulting in optimum illumination in all situations. What's more, these headlights also automatically adjust the height of the beam as the vehicle load changes, doing away with the need for fiddly and less accurate manual adjustment.
These headlights are also made special by the fact that they are able to turn asymmetrically. In a right-hand bend, for instance, the headlight on the right will turn more sharply than its counterpart on the left (15 and 8 degrees respectively), allowing drivers to see the inside of the bend or the side road far more clearly while the left-hand headlight maintains optimum illumination of the area to the front of the vehicle.
The result: the road ahead is lit up to maximum effect, improving levels of visibility and, consequently, safety. The intelligent bi-xenon headlights with AFS expand the effectively illuminated zone when cornering by up to 30% and increase the distance at which objects ahead or cars in bends can be detected by as much as 68%: at a speed of 70 km/h, this would give drivers an extra 1.8 seconds to react.
