Actuator???
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
ive asked this question before as a mate of mine is deeply into his rs turbo's and is a regualar thing to adjust the actuator on the rs turbos as it holds the boost ect but wouldnt be a wise idea on the beezer :no: too many sensors destined for trouble! have you got a remap yet for your sooty completey changed my petrol!!!!!!!
gazjones
the tdi does have one bu if you adjust it it can over boost and bad things can happen old school turbos that were mostly mechanical can be adjusted but modern turbo cars all rely on valves and sensors
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
A petrol turbo engine with a carburettor can have a bleed valve and the actuator adjusted and lots more to the point of black smoke
but now way attempt it on an engine with electronic fuel injection and a cat :ban:
gazjones
all mk4's are the same height so think only diference is the rating on how stiff they are
gazjones
a bit yes you can get lots of springs that are 30mm lower that makes it look just right imo
gazjones
shouldnt rub any more, shouldnt rub at all as that is the cupra's tyre size
rashcupra
Oct 15, 2006
6,517
crawley
DIESEL :no: :hide: its a petrol mate will be exactly the same suspension thats on the diesel cupra tho make me an offer mate :shrug:
bigjode
504
I've adjusted my actuator - only raised peak boost slightly from 19 to 21psi but holds the boost a bit better through the range.
It won't cause any problems if done sensibly, in the States they do it all the time with very people having problems.
Lots of people say don't do it on these cars but most are just passing on info they heard elsewhere and haven't actually done themselves.
