A trip out of Rochdale today, and a drive north to Lancaster.
Here's the car on my 9am arrival:
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2690.jpg?t=1168954086
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2692.jpg?t=1168954136
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2694.jpg?t=1168954158
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2693.jpg?t=1168954184
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2691.jpg?t=1168954209
First job was the Dp foam, left to sit for a couple of mins, and rinsed off, then as it was still pretty bad, DP'd it again, and used the one buscket rinse. The alloys and araches saw some APC to help me out with getting then clean. Rinsed again, and then used the DP foam as lub to clay using DP clay. DP clay is pretty aggresive, so wanted lots of lub so as to not get any marring. Once all done, and rinsed, again!, dried with Cobra guzzler, taped with 3m and PDG readings taken.
Here are the PDg readings and the used DP clay:
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2695.jpg?t=1168954342
Next up, the halogens and the swirls and scratching.
Here is the swirling shot:
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2698.jpg?t=1168954518
and now in close for the scratches:
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2696.jpg?t=1168954415
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2697.jpg?t=1168954451
No messing around, out with the Metabo, a wolfgang polishing pad and the Pinnacle SR. Worked at 700rpm, swirls gone. Scatching however still very evident. What followed was a good hour or so of me playing with technique,pad and product combos trying to find the lightest combo to retify and resolve. In the end I stuck with the Polishing pad, and used Pinnacle Advanced Swirl Remover at 1500 rpm. This was then followed with another Polishing pad and Pinnacle Advanced Finishing Polish at 1100rpm.
here's the bonnet and wing afterwards:
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2699.jpg?t=1168954775
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2713.jpg?t=1168954802
Couple of shots from around the car using the brinkmann flash light:
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2700.jpg?t=1168954855
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2704.jpg?t=1168954878
Next, using the PC, a finishing pad and Clearkote red Moose Glaze, applied at speed 2 to allow a nice light glazing. This was then topped with DP Max Wax. Alloys sealed with Megs #20, glass cleaned with Stoners Invisble Glass, and Tyres with Armor All gel.
Here are the Post Detail shots (all inside I'm afraid as it was dark as the ace of spades outside and raining).
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2705.jpg?t=1168955175
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2706.jpg?t=1168955198
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2712.jpg?t=1168955219
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2708.jpg?t=1168955245
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2709.jpg?t=1168955265
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2711.jpg?t=1168955289
http://i146.photobucket.com/albums/r272/finerdetails/JonWiseguy/IMG_2710.jpg?t=1168955309
Thanks for reading
Iain
Thanks for reading
Iain
