ABS warning light
taffyR
84
TREALAW/ RHONDDA S.WALES
Ive just changed the front drivers side abs sensor on my mk3 ibiza cupra R.
The magnet snapped while fitting a new hub/bearing.
This caused the abs warning light to come on.
After fitting, the light stayed on.
Does the fault output have to be reset by vas or vag com????
Anyone help?:confused:
BJ
Nov 2, 2004
9,335
South Wales
Disconnect the battery for a bit then re-attach, see if that does the trick.
If it stays on get it vag com'd.
In fact i'll vag com it for you if you want.
taffyR
84
Cheers fella!
Ill try the battery tomorrow, first thing
Whereabouts are you in case i need to access the diagnostics??
The MOTs due and i think itll fail if the fault light is on....
taffyR
84
Try the battery first, i live in treorchy. Seen you about a few times as well.
Heard you've had your car mapped again?
Havent we met with ***************?
yeah, I took it up to Owen Dvelopments in oxford to get the motec
properly mapped.
It was giving far too much torque.. 375lb/ft @ 275bhp
Now its a far more driveable 260lb/ft@300bhp
Mark, up there is one of the top guys for motec, he done a
superb job.
The initial ihi/motec upgrade by TSR mechanically was good
but the set-up ,wiring and mapping was a **** up.:funk:
Nov 2, 2004
9,335
South Wales
Yeah, i chatted to you at the meet before.
Glad to hear its all sorted tho.
Let me know if you need a hand with anything.
taffyR
84
Your car looks nice.....
Impressive performance figs too
Standard turbo??
If you are passing, pop in anytime.
We can have a chat and perhaps swap tips and info.
Im on the main road, opposite side to the chippie by the res.
Big white house on the corner, right on zebra crossing. (my garage is down the sidestreet)
Gis a ring first on 0790 230 3788. to make sure im there and not in work.[B)]
