Performance difference with ICE
stevecupra
53
Derby
Just wondering, what would the difference in performance be with a boot install weighing the car down. Its a 20vt (180) with revo. In the boot there is a double 12 inch sub box and an amp rack with 3 amps in it. Will it even make a difference to the 0-60 times?:shrug: :confused:
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
Probably not. Infact, you might find you get better traction.
Think again! On a FWD car, adding weight to the back of the car will just exagerate weight transfer even more, so making traction at the front wheels even worse.
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Depends how far the rear suspension has been compressed by the weight of the hifi i guess ... mine was already sat low at the back, when i fitted the 30mm lowering springs and uprated dampers the rear of the car didn't lower any further but the front came down to match it.
Since fitting these the handling is a lot more surefooted - will need the rear ARB fitted to sort it out once and for all as it's still a bit wayward :)
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
From experience I can say yes, it will have an effect. More on the 0-60 or 0-100 times than the in-gear performance, as once moving weight isn't as much of a problem, although it still slows you down.
Adding 100KG of weight - which is very easy with ICE, MDF, sound deadening, cables etc - will have a noticeable affect. Try finding a fat friend, or two average friends, and stick them in the back of your car and see if it still feels the same.
LiCkWiD
LiCkWiD EvOLuTiON
Nov 15, 2006
892
Essex
The time difference will be negligble, unless you're setting yourself up as a 0-60 sprinter on a more regular basis.
I'd forget about the .5 of a second or something that comes from the extra weight. If you get bitten by the weight bug, you end up tearing our comfy trim and "unneeded" panels. It works both ways. It'll only make a difference if you're seriously trying to shave nanoseconds of your 0-60 times.
The weight in this system is not centred over the driving force, i.e. the front-wheels. That said, the increased weight is not spread evenly over the wheels, therefore this will only have a slowing effect. Definitely not a traction-inscreasing one. Fact is, the car will be slightly lower on its arse-end now. Not an ideal situation for an FWD. Nevermind.
RobM
Sep 27, 2006
4,982
Southampton
When I had a similar, fairly hefty in a Focus I had I did notice a difference, but as said above, it wasn't huge unless you're constantly doing standing starts or trying to get good 0-60 times. When I really noticed it was when I removed it all! :blink: The difference in the way it accelerated and the way it felt through corners was quite a surprise. The car felt like it had gained power and felt much more nimble.
Snoopie
Impossible
Feb 5, 2006
349
Enfield
On ice and snow in the older days.. They use to put bags of Potatoes etc in the back of extra traction going up hills and moving off. :)
Although I see your theory..
stevecupra
53
Derby
Ok, I think if it does not make that much difference i will keep the quality sounds and sacrifice the half a second or so. Cheers
UncleFester
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Haha compared to the rate the fronts wear at i've not noticed any problem. I just find it sits better on the road and seems less 'light' at the rear. Most of the time I only carry me in the car so it's not much of a weight increase. I think especially on the Diesels, there's so much torque once you're moving that fuel economy barely changes?
LiCkWiD
LiCkWiD EvOLuTiON
Nov 15, 2006
892
Essex
Heh, I did wonder about that also, DPJ. I thought maybe people were getting confused as to which wheels pull on a Leon :D
Reg
Oct 10, 2005
962
Berkshire
Its more than just theory! As DPJ says, RWD cars this would be true. Ask someone who used to own a Capri. It was popular to carry a little weight in the boot to try and get the tyres to dig in a little.
But on a front wheel drive car you are changing the balance towards the back, away from the driving wheels which will scrabble for grip even more.
LiCkWiD
LiCkWiD EvOLuTiON
Nov 15, 2006
892
Essex
No dan, you idiot. Christ. Power is routed through the stero volume nob. Christ almighty, give me strength Lord! :D
