pishtail
Might seem like a bit of a numpty question
but can anybody tell me how to remove the side light bulb.
I have removed the access cover and can actually get hold of the bulb holder
but there doesn't seem to be an obvious way of releasing it
Pishtail Mk1 Leon 20v se
Pishtail
If its is the side light your talking about, then if u can see where the 2 wires go into tha back of the bulb casing? well grab them ans as much casing as possible then give it a slight twist (any way) and just pull, its completly round and has no fixings other then friction, nice snug fit
Hope this helps (try turning them on when replacing top tip to see what your doing
Good tip if your using LED's, but if they are normal bulbs you WILL burn your fingers. They get hot quickly like any other bulb.
Im having the exact same issue. I just can't get the bulb out, I can spin it 360 had some some pliers on it and didn't budge at all.
Is brute force really the way to go?
Pull hard, try not to use the wires... Pops in and out easy after the first removal
Hi guys, I got it done. While trying to get them out I spotted that there are two clips on the bulb holder, which when pushed in allow you pull it out with ease.
I tried getting a photo to help explain where they are, but it didn't come out well enough.
If you twist the bulb holder so the cables run from top to bottom, then look at where the holder meets casing, there are 2 groves on the left and 2 on the right of cables. The tiny piece of plastic between the groves is actually the top of the clip that holds the bulb holder in the casing. Pushing both in at the same time (pushing one in is enough in some cases) and pulling on the holder releases it quite easily. Though I must admit, pushing these clips in is very fiddly. I used jewelry screwdrivers to do it.
Eliminates the risk of breaking the holder in a fit of rage!
Hope this helps someone.
hammer time.........
Hi i had the same problem side light, was tough to get out now used pliers and out it came, but now the bulb doesn't light up 😩. I must have disconnected one of the wires? Nightmare it wasnt even broken to start with was only changing it because I had a set. Anyone else had a similar problem?
