has anyone seen a drop in boost presure sinse doing the bypass..?
I did mine a couple of weeks ago and lost 2-3 psi.
mind you i did take the shield off the dynatwist at the same time, but i don't think that'd make much difference, especially in winter.
Thing is a dynatwist is designed to work with a heat shield, whereas an open cone filter isn't... so by removing the shield your actually removing part of the "build" of the induction kit.
I would say put the shield back on and see if you gain those 2-3 PSI back...
The shield on the dyna wouldn't cause a boost drop - the air may be hotter but the turbo boost shouldn't decrease. Infact some say warmer temps cause higher boost as the ECU requests more as the air is less "efficient".
I disagree but also agree on parts lol
