Any any off the non Seat Front Brake Pads for Cupra R have the metal plate?
kwan88
223
Slough
Visit site
Dear All,
I was one that brought the Gaffer front brake pads and found out not that they killed the disk. But that at low speed they make a noise as they move a little in the caplier. It was only after looking at the orginal Seat Parts that they have a extra piece of metal plate welded to the pads which reduces this noise.
Can anyone tell me if the other brake pads have this item?
Regards.
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
Anti-rattle spring you mean. Most if not all brake calipers will have this. Its a part that goes with the caliper - not with the pads.
Nov 27, 2006
1,204
www.cardomain.com
Sounds like he means anti-squeal shims on the back of the pads.
I've not got these on my Brembos (Renualtsport) and never heard them mentioned on the LCR :confused:
Hairy
590
Wiltshire
Do you meen these...
left to right, SEAT (hard to see as it's black, but does have a shim), EBC Red Ceramic, (obvious black shim), Galfer 1055, (no shim).
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Dear All,
Regards.
i didnt fit the original metal plates onto my 1045 galpher pads... however i did put copper grease on the back of the pads (as i ALWAYS do) and yet again i do not have squeeky brakes! ;)
so i suggest if the squeeky brakes are annoying you, you simply take the pads out and apply some copper grease to them! :yes:
good luck! :)
kwan88
223
Slough
Visit site
Yes it is the shim. I applied lots of copper grease but the noise only occurs if you go forward, brake a little and then reverse and brake a little. The noise sounds that a glunk.
Are they other pads that peoplease have used that have the shim?
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
the noise you are describing sounds more like the suspension to me!
im 99% sure i know the noise u mean, as i noticed mine used to clunk sometimes, when moving forwards a bit, then backwards and braking!!!
this is nout to worry about, its normal... as it goes since i fitted my coilovers the car hasn't made this noise! :yes:
