ok so do the later dab's have both then?
how do you adjust the angle of the head unit mine (i mean the wifes) has brightness adjustment but i cant seem to set it so you can read the display without having to duck down to see the display clearly, the i pod connector fits in the cd multi changer section on the rear or the unit so i should think it a easy job to plug in a din adaptor unless someone does a ipod to din?
So does the stereo accept an SD memory card then?
Thanks.
Norrie.
