Photo Request - Suspension Top Mount Bearing
Nov 2, 2004
9,335
South Wales
What do these look like? I just ordered some from ECP and they look like rubber doughnuts. 7.50plus vat. Sound about right?
Any help would be good. Cheers.
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
Yeh same here too, please can you post the part numbers. Mines been knocking for a while so i will order them from ecp n see if that cures it.
Nov 2, 2004
9,335
South Wales
I got the top mounts from here...
http://www.vwspares.co.uk/ibiza99_suspension.php
Part bnumbers (taken from above site)
Front
6N0412331E
(6N0412331D)
Rear
Replaces OE Ref:
191 512 333 (Lower)
191 512 335 (Upper)
Top mount bearings... (taken from the box)
6N0 412 249 C
Can someone check these with etka to see if theyre ok first.
Hope that helps.
9,335
South Wales
All done. Bye bye clunking. :D
Camber is way off now because i think i put the top mounts back in a different way i.e rotated from the original position, plus the fact that the bearing raises the suspension a little has made it all over the place. Will probably whip it off after a drive and see if i have rotated the top mount.
R0b
104
Sorry to hijack but would you reccomend i fit these when fitting the coilovers i just bought?
