cupra holding back
rich2310
for the past few weeks my mk 3 cupra has been running like a bag of sh*t some days it wil boost really well then others times it will really hold back on you its like the turbo is not there, also i was out today just going along at 60mph looked at the temperature gauge and the needle had dropped right below the 60 mark and it has never gone below 90 whilst the engine has fully warmed up.
my car is standard apart from a forge dv007 and cat back stainless steel exhust system
any suggestions wat the problem could be?
is there any1 in the dorset with vag com who would be willing to do a diagnosis on my car
cheers
cupra1.8t
leeroy
Nov 21, 2006
213
tamworth
i have got the same prob with mine mate **** knows wot it is sick of spending money on it now ! let me know if you sort it cheers lee
cupra tda
64
sounds to me like your maf is knackard, i had a simular prob with mine and this solved it.
rich2310
had my maf changed about 3 months ago would vag com tell me if the colant sensor has gone
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
It might not actually come up as a fault, you'd have to go in and look at the values being sent from the sensor.
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
Sounds like it !
Anyone know roughly how much it is ?
£15 from GSF and a VERY VERY easy fix. The new ones are green, the old ones have known issues (or at least known 'short lives').
Part number is available in a post I was involved in about 2 months ago, so search and it will be there.
VAG COM DOES show the temp sensor has a fault (engine management light comes on too, if it's serious enough). Mine was showing 'implausible signal' as well as signal out of range. It's completely possible that yours is broken but not throwing up dubious enough values to cause the ECU to notice and log a fault.
Rich
Oct 17, 2006
893
Walthamstow
boost problems will be the death of me - I had a coolant temp sensor message - then discovered it was a spilt hose - but then a day later, its going back in to limp mode!
Joy
cupra1.8t
leeroy
Nov 21, 2006
213
tamworth
cheers lads sometimes it boosts ok like just then it stops does it when it feels like it ?? that still sound like maf or temp ??
