Tempremental climate control
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
My climate control seems to increase the fan speed all by itself. Ill turn the temperature up to Hi cos its cold at night, the fan speed will be on bout mid way when i stop pressing the button,
and all of a sudden ill look at the display and its up full whack, it does it on other temperatures as well
any ideas? or is this normal
sargey
Aug 16, 2006
324
so basically until i burn to death. marvellous well thanks for that, ill tell my girlfriend that next time i turn the temperature up the car is going to try and cook us ;-)
cheers!! :)
Pabs
5,936
Basingstoke
you'll find it uses some "intelligence"....
If your engine is cold, it won't pump cold air into the cabin, so it'll keep the fans on low until the air is warm enough to warm the cabin up to your chosen temperature. If your chosen temperature is "Hi", then of course, expect to be cooked. Because "Hi" means HOT. :bleh:
I don't think i've ever had my temp settings any higher than about 24, and that is a little too warm for me.
Even the manual mode isn't fully manual - if you ask for Hi it just won't let you force the system to pull in cold air.
sargey
Aug 16, 2006
324
i leave it on hi for about a couple of minutes so im nice and toasty then turn it down, sometimes i forget and i start to get a nice tan lol
Pabs
5,936
Basingstoke
well then you've only got yourself to blame - ;)
a bad worksman always blames his tools! :D
sargey
Aug 16, 2006
324
tropical my arse! westons either wet windy or cold!!
When i get in my car in winscombe (visiting the significant other) its normally cold in my car! hence the heating
