just standard shocks and springs suspension kit, i cant afford the coilovers.
Hey local boy.
I don't think its a matter of how big a drop, as with the 1.4's, standard suspensions varied as to where they sat from the many I've seen.
To be perfectly happy with a drop, get an adjustable susp. Most after sales suspensions were designed for the GTI's, so with less weight up front, it's not gona b perfect. I think with some adjustables, you can change damper settings too, which would mean just tinkering with heights and stiffness until happy.
That way, it gives you the option of height alround, so you can adjust until you're happy, rather than taking a gamble. That's what I'd do if I still had my 1.4, or even with my current car.
post hi-jack!
does anyone know if a 60mm drop on 17' would be ok? ie any scraping?
itll scrape on full lock pretty much guaranteed, and youd probably have to 'alter' your wheel arch linings and what not to make them not rub
dont be fooled tho, coilovers get softer the lower they are wound down!
i have mine lowered on 17" lowered 60mm and have no problems at all
