vagcom fuel filter check
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
i remember reading somewhere that you can use vagcom on the Pds to check the fuel filter state , block 20 is familiar as is - 50 and +50 but what is the proper way of this
thanks as ever
stephen
PS can you make this a quick reply please :shrug:
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
dunno about the pd's but in the petrols you can check systems in the rediness section of the engine details or run the output tests and you will see/hear each test running.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
this is done in measuring blocks at idle , somethignt o do with injection pressure or something , is driving me insane finding it and looks like tdiclub is broken--wasnt me honest
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
posted this up ages ago , and today found the file on an old back up DVD
feel free to comment
txt from file :
ok all you vag-com ers check this out using your vag -com go to engine, click 08 value block then 023 readding for fuel filter flow will show -50 and above will be filter gettiing plugged, a good filter will show -50 and below, check it out this solved a few no power concerns i have had with p/d also it doesnt matter what fuel your using. i have seen both,
please report as before ,
cheers as always stephen
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
I coudn't make sense of it either
well i took it as was to go to the engine block , 08 as it says above takes you into measuring blocks and block 023 is an unmarked set of 4 fields , trouble is on my car the numbers were all over the place so didnt know which one to believe :confused:
