Couple of Vag com Q's for FR TDI
daveyonthemove
Smile if you like SEAT's
May 14, 2006
1,519
Wrexham
Can anyone point me in the right direction please?
I have a FR TDI and received my (genuine) Vag com cable today, and it all works well.
I'm trying to find out how i can do a couple of things:
1) Find out my boost values while driving.
2) Switch conveinence module on or off.
3) Log 0-60 times (we all want to know deep down)
4) how to get the "TDI GRAPH" to work (if it's compatible at all?)
I've had a look through most of it before the battery died on the lap top, and even figured out how to revert to standard from my Remap ( quite a difference too i'm pleased to say)
Any hints, tips or user guides would be a great help.
Dave
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
In my Beeza tdi
Group 003 - Specified vs actual MAF Intake
Group 007 - Air Intake temps through your intercooler
Group 011 - Specified vs Actual Boost pressure
Might not be the same for yours but it might help ya...
daveyonthemove
May 14, 2006
1,519
Wrexham
Got it working, cheers for your tips.
Just managed to get one 0-60 log in as it's rush hour and there isn't enough road for me to be driving fast.
Bearing in mind i removed my remap today and drove it see the difference, and then put it back again without driving it for more than a mile, i managed to log a reasonable 0-60 in 7.2 seconds.
Can't wait for the map to adjust properly, it should get in the high 6's i hope :D
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
what was th plus and minus values?
How often does your Vagcom take readings?
Mines 0.5 sec so times aren't too accurate
daveyonthemove
May 14, 2006
1,519
Wrexham
Not sure on how often it reads TBH, i'll have to look into that.
+/- was 2.5
5 seconds was a bit optimistic, and 9 was slow even for standard, so i assume it isn't far out.
What would you think?
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Mine reads 7.0 +/- 0.5 so 6.5 or 7.5
Bearing in mind i got 6.93 at Trax and 6.38 using a G-tech..
I did get a 5.6 secs +/- 0.5 30-70 time!
daveyonthemove
May 14, 2006
1,519
Wrexham
Mine could be faster then.
I'll have a look at changing the read times and give it a go once the map is settled again. Might turn TCS off too this time.
