Alana
ibizasport16v
217
Clydebank
I want to replace my alana headunit on the mk4 ibiza, but when i went to fit my sony headunit it didnt sit flush and didnt lock into place, im guessing im not the only one to suffer from the problem due to the shape of the dash, im just wondering if anyone has got a suitable replacement headunit (£250 max)which fits perfectly?
gazjones
i found that the cables at the back need sorting out and moving around to allow the head unit to fully slide in its a real pain ive cut most of the carride at the back
also fits better and the bottom as there is more room to move the cables!
gazjones
you can swap the radio and cubby hole around just need to flip the cubby hole upside down and it fits perfect
gazjones
mine is there and is easier to control while driving as its so close to your hand on the gear stick
mpm1987
Spanish Donkey
Mar 10, 2006
356
i fink if ya push n hold a button, it puts it on repeat n mute, one of the number buttons???
BJM
739
Houston, Renfrewshire
Push and hold number 6 - think thats repeat track! It als has shuffle and other fuctions like that - it's amazing what you find out by reading the manual!
Icecavern
6,214
Berkshire, UK
www.icecavern.com
take the top out of the glovebox ( about 4 or 5 torx screws ) and then you can pull the wires back from behind the HU. Then they fit easy :D
