Aircon Should it do this?
daniel_owen_uk
270
Chesterfield
Ok temperature is getting colder, dropped to about 0.5c last night, and since then, the aircon won't switch on.
When I usually press the windscreen button, it usually switches the aircon on.
It doesn't I just got the symbol that flashes up then goes away.
Pressing the aircon button does the same.
Does it not work when it's cold?
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
Wont work below a certain amount of degrees. cant remember the exact number.
Says this in your manual!
daniel_owen_uk
270
Chesterfield
For reference manual says;
"At low outside temperatures (less than +5C) the refrigeration group (compressor) is automatically switched off, and may not even be switched on manually."
(air conditioning - 2.89)
foon
In case you're wondering it's 'cos the condensed water might freeze in the outlet pipe (in the footwell), plug the outlet and knacker the air con.
