What are your mass flow readings from VAG COM???
ice maiden
Those of you that have used VAG-COM, could you please post your average mass flow readings, and also if you have a remap etc?
Apparantly mine is low......but I want to compare with others.
gazjones
yes but i was using it as a guide to what 236 is as thats what her car put out with revo off so should be roughly the same as that and is 20g/s higher with revo on her car
might help i dont know lol
gazjones
looked a scotty's readings yesterday on hear think he got 200g/s with stage two
ice maiden
No it will be different Gaz for an LCR I have been told that much
ice maiden
Scotty has stage 2 revo so should receive a higher reading I have spoken to him earlier about this
Tallpaul
821
What is yours?
A very rough approximation of what it should be is 0.80 of your stock bhp.
ie if your running with REVO switched off you should log about 180g/s @ 6000rpm.
ice maiden
mine is apparantly to low at 197.5
I was told i should be looking at around 205 -210 today
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Code:
Sunday	22	October	2006	10:43:34
1ML 906 032 A  		1.8l R4/5VT         0001
	Group A:	'003				Group B:	'020				Group C:	'004
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Voltage	Temperature	Temperature
	TIME					TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	 V	°C	°C
	0.93	2320	30.33	19.2	26.3	1.33	0	0	0	5.3	0.53	2280	13.72	88	32
	2.14	2360	13.39	10.2	34.5	2.54	0	0	0	1.5	1.74	2360	13.93	87	32
	3.34	2520	59.19	100	18.8	3.84	0	0	0	0.8	2.94	2440	13.79	87	32
	4.66	2840	102.44	100	8.3	5.06	0	0	3	0	4.26	2720	13.86	87	29
	5.86	3240	116.44	100	6.8	6.26	0	0	2.3	0	5.46	3120	13.93	87	27
	7.07	3640	131.86	100	6.8	7.47	0	0	2.3	0	6.67	3520	13.86	87	27
	8.37	4080	144.17	100	9.8	8.78	0	0	1.5	0	7.97	3920	13.93	87	27
	9.68	4480	155.44	100	12	10.19	0	0	0.8	0	9.28	4360	13.86	87	29
	11.09	4880	167.06	100	9	11.49	0	0	0.8	0	10.69	4760	13.93	88	32
	12.4	5200	181.47	100	9	12.8	0	0	0	0	11.9	5080	13.86	88	34
	13.61	5480	182.72	100	8.3	14.01	0	0	3	0	13.2	5400	13.86	88	37
	15.01	5760	188.17	100	7.5	15.42	3	3	3	0	14.53	5680	13.93	88	39
	16.32	6000	188.78	100	8.3	16.83	2.3	2.3	2.3	0	15.82	5920	13.72	88	42
	17.63	6200	189.97	100	12.8	18.14	2.3	1.5	0.8	0	17.23	6120	13.79	88	45
	18.94	6400	190.61	99.6	10.5	19.34	1.5	1.5	0.8	0	18.53	6320	13.86	88	46
	20.25	6520	193.69	100	12	20.65	1.5	0.8	0	0	19.76	6480	13.86	89	48
	21.57	6680	195.58	100	10.5	22.06	0.8	0.8	0	0	21.05	6600	13.79	89	48
	23.05	6520	14.64	11	9	23.47	0	0	0	0	22.57	6680	13.86	89	48
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Code:
Sunday	22	October	2006	10:44:59
	TIME					TIME					TIME
	1.44	2400	57.86	96.1	15.8	0.53	0	0	0	0	1.04	2320	13.79	87	26
	2.73	2760	101	100	6	1.84	0	0	3	0	2.33	2640	14	87	24
	3.95	3160	114.31	100	3.8	3.15	0	0	2.3	0	3.55	3040	13.93	87	24
	5.15	3560	123.25	100	8.3	4.35	0	0	0.8	3	4.75	3440	13.93	87	24
	6.56	4040	141.28	100	6.8	5.66	0	0	0.8	2.3	6.16	3920	13.79	87	26
	7.96	4440	152.81	100	12	6.97	0	0	0	2.3	7.47	4280	13.79	88	29
	9.37	4920	166.42	100	6.8	8.38	0	0	0	0.8	8.88	4720	13.93	88	30
	10.59	5160	176.58	100	9	9.79	0	0	0	0	10.19	5080	13.93	88	33
	11.79	5440	188	100	8.3	10.99	0	0	0	0	11.39	5360	13.93	88	36
	13.1	5720	126.83	100	18	12.19	0	0	0	0	12.6	5640	13.93	88	39
	14.52	5840	110.44	100	24.8	13.5	0	0	0	0	14.01	5760	13.93	89	39
	15.91	6000	175.11	98.4	16.5	15	0	3	3	0	15.42	5920	13.93	89	39
	17.13	5880	13.44	10.2	6	16.31	0	2.3	2.3	0	16.71	5960	14	89	39
	18.44	5800	35.19	22.4	21.8	17.53	0	0	0	0	18.04	5840	13.93	89	37
	19.75	5840	103.06	34.9	29.3	18.94	0	0	0	0	19.34	5840	13.93	89	35
	21.15	5760	15.42	12.5	34.5	20.15	0	0	0	0	20.65	5760	13.93	89	33
