LC upper front strut brace instalment help!!
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
they arnt difficult to fit but requires drilling pilot holes and using self tapping screws (strong ones)
if you ever have an accident though the strut brace will turn a one sided impact into probably totallying your car, did you not think of getting better anti rollbars or the audi s3 lower strut brace?
haz420
kool, no not really cordobabrandy just been reading here and lodz of peeps have bought this. I will go to B&Q or sumfin and see hwat can i pick up. And Brummy I have emailed him few times but no joy.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
haz, before you actually drill the pilots, trial fit the brace and use tippex to mark the dead centres of the holes, if you dont the holes wont be square to each other and could be more hassle than its worth, good luck.
NeilC
Has left the fold...
Mar 23, 2004
336
somewhere else
Self tappers? You just need some m8/m10 bolts and some nuts to put on the end (nyloc so they dont come undone might be an idea).
Drill some pilot holes/holes (i'd pick up a decent set of bits from b&q while your out as you need to drill through about 6mm of steel). You can get access to below by turning the wheel on full lock or better by jacking up the car. You'l prob need a couple ratchets and extension bars.
Dont forget to paint some hammerite on the holes or use some sealant to prevent rusting.
haz420
mmm intersting im going to B&Q now lets see what i can get. Also i about to install splitfire boost guage will post some pictures once its done.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
neil the sparco brace that i got for my old cordoba came with strong self tappers, if its good enough for them!
I also see a bonus using them, if you have a side impact the self tappers will only hold on so much before coming out, bolts will pull the fook out of the other turret and the insurance co. will not pay up for that damage unless its declared.
WeeJase
pert
Jun 2, 2001
8,595
i binned my sparco ones after shearing 3 of them off.nut and bolt all the way IMHO
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
The only pics i can find are,
and
though they dont show the bolts.
