i seem to have a real hanling problem with my mk1 cupra turbo, i'e it just doesn't want to turn in and it feels (wooblyhas anyone any ideas what i should be checking/looking at.
i seem to have a real hanling problem with my mk1 cupra turbo, i'e it just doesn't want to turn in and it feels (wooblyYou need an anti-roll bar to help eliminate the symptoms you describe.
i have checked all tyre pressures today and they are spot on with what it should be, 33psi rear and 36front if i remember right. in the wet, its even worse, would a strut brace help? can i fit an uprated anti roll bar with uprated bushes?
i am the same m8 mine goes well in a straight line but don't cut in the corners so i am going for a set of fully adjustable coil-overswhat shocks do you suggest, and would you suggest coil over's and adjustables?
Mine handles brilliantly but then I do have the full works including a diff.
Coilovers are expensive and needless IMO unless you plan to do lots of track work. If you've got the reddies go for it. Damping adjustment is essential and ride height will tend to be adjustable on those items too
