it keeps happening
teeth2k
908
sussex
Visit site
ok i have a 2.0 16v cordy (abf) and on most journeys i could be going along and i want to pick up speed so i put the peddal down more and the engine splutters i take my foot off and it runs normaly but as soon as i put my foot down she die's
i restart the engine first time and she goes normaly.
ok can anyone help me b4 i try the trial and error tactics
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
well thats the first thing id change, infact i did onl last week, picked up a pack of ngk plugs for 16quid from halfrauds, although mine is an 8v
5mins to swap them over and the car felt instantly better
could be 1 of a whole bunch of things though
teeth2k
908
sussex
Visit site
yeh that was gonna be my main focus for attack iv just had the plugs out and they are dry and fine a little carbon build up and i just used some sand paper to remove some build up and see how this fairs
just another idea it could be what about air filter/blockage in pipes?
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Visit site
I have a the same recurring niggle with mine, happened 6 months ago then it righted itself until last friday leaving work.
sometimes its fine, then the next time you drive its like a sack of ****, then the nest time you drive its fine.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
sounds daft but check the pipes for air leaks too
my servo pipe had rubbed through and seemed to do similar
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
top right of the inlet manifold as you look from the front
comes out backwards into a valve (make sure the small pipe has a green cap on)
then bends 90 left along bulkhead onto the servo just to the right of the master cylinder (where you put the brake fluid)
iirc theres a small bore pipe also goes off to the right round the strut top and another coming off the throttle body that is worth looking at - just visual check em to be safe - never know
you'd probably feel you have to brake harder if the servo wasnt fed with vacuum properly but then mk2's always feel like that to me anyway :)
teeth2k
908
sussex
Visit site
why does this only go onece whan its wet im confused ??? its sooo strange in the dry it conks out 3 times in the wet it only does it onece arghhhh
mcdougalld2
i have the same prom its ok when its cold then when she warms up its like driven a 1.0 its is doin my head right in eny one hlep me that wd be good like i love my cat i have the 2.0gti 8v:think:
