beding in 312mm tt setup
gazjones
hi just fitted my 312mm setup and everything is good pedal feels good only one question they are slightly steeming with a slightly funny smell on them is this just the coating on the disk being burnt off or them getting very hot at the pads arnt settled in properly yet?
thanx for any suggestions glad ive finally done it!
Tom B
4,710
16
Northampton
It could be the copper grease burning off a friction point, go for another quick drive and see if it still happens.
gazjones
ive been out twice its not copper grease they just seem very warm even the wheel is warm when i come back!
mrcoyote
See no evil...
Jul 26, 2004
2,624
Does sound like it's just the protective oil coating being burnt off. As Tom says go for a bit of a drive and see whether it's gone away.
mrcoyote
See no evil...
Jul 26, 2004
2,624
You did push the piston back far enough so the pads don't rub while the disc is going round didn't you?
Tom B
4,710
16
Northampton
I didn't realise these were new.
I got my brakes done 2 weeks back and they smelled for a few days while the oil burned off...now they've bedded in, the smell is no more!
gazjones
this piston was pushed right in i can rotate the wheel pretty freely so its only gliding on the surface of the disk but they are basically brand new from golfturbo and still have the machine lines in the disk
also when coatsing the car dosent slow down much no more than before so dont think the pads are too tight on the disk
TTS Roadsport
VAG specialists
Apr 24, 2006
229
Bedford
www.ttsroadsport.com
New discs and pads can take over 200 miles to bed in properly. They will be a bit poo until then. EBC redstuffs on Black Diamonds are the best for lots of smoke. Its just the coating. Nothing to worry about.
Just be careful for a while:)
gazjones
cheers for that thought it was just them bedding in the pads are slightly curved on the face so prob a small contact area creating lots of localised heat making them very warm doing about 60 or 70 miles tomorrow so hopefully will see a bit on an improvement!! cheers everyone!
helms
Console Race Car Driver
Jan 30, 2005
492
Basingstoke
its the packing grease on the discs burning off , you should of ideally used a de-greaser on the discs b4 fitting
exactly what i was ging to say, should have cleaned the disks with meth spirit or something first.
Brakes done really need to be bedded in as such, obviously dont fit them and then go into a hairpin bend at 60, to see how much shorter your stopping distance is, but aslong as you dont glaze the pads befor you get through the first layer, then just brake normally.
gazjones
been driving around braking alot but not really hard the odd few times just to see what its like but not had to break in anger yet and dont really want to either
