Just had the Custom Code stage 2 remap :)
GaryM
Golf GTI 1.8T 180
Feb 11, 2004
378
Nr Manchester
Not sure on the cheap third party ones off ebay. I have one (serial) which I use with Custom-Settings/Lemmiwinks. It will work with Vagcom but only the older 3.12 or whatever version it was. I have a USB legit cable for full on vagcom use.
TBCupraT
Limp Mode Squad ™
Ninja said:
I would happily post logs but never managed to get vag com working.. Think its probably a dodgy cable as i've tried it on 2 laptops!
Will try to get a new cable sorted.. is it ok to just get a cheapy one from ebay ?
If you wanna meet up with Helms and me in Basingstoke I'll be happy to do some logging with you on the A33.
I often meet bezzaboy in B.stoke. I could arrange to get him down as well and we could do some comparisons between the JBS04 and stage 2 K03s.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Did anyone ever compare the JBS04 and the stg 2 KO3s.
Can i ask what is involved in making a K03S stage 2?? I only see 12-13 psi @6k.
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
Not really.. I tried 2 different USB cables on my laptop but never got it to work :(
Am sure there must be someone near reading that could do some logs for me ??
Failing that im going to the Marlin Rolling Road next month so hopefully someone will bring it then and i can get some graphs logged...
Mine seems to peak at like 23psi and then hold it just under for quite a while in most gears... :)
Ibiza Cupra
Well i'm on a KO3 and i hold 10 - 11psi. If a KO3s only holds 12-14psi is there any point upgrading???
