I'm hoping someone can shed a light on if my MAF sensor needs replacing.
My car started idling very badly the other day travelling from Brighton to North Yorkshire in the inevitable hold up on the M25. I was only half way there but still managed to drive the remaining distance and then back again a couple of days later. The car runs fine at higher revs its just idling and at lower revs that its a problem.
When idling, the revs drop to around 800 rpm then increase to around 2000 then drop again. Looking at other posts I think it could be the MAF sensor. I have a draper diagnosis tool and have the code P0171 System too lean Bank 1. The draper tool allows me to track the MAF output I get the following readings.
RPM MAF in g/s
800 8 g/s
1500 15 g/s
2000 20 g/s
3000 23 g/s
4000 34 g/s
5000 43 g/s
Do these readings look right? I cant find any list of the MAF readings other than peak readings for you guys with modified engines. I should maybe say that the car was stationary when I did this and the air filter was disconnected, I dont know if that would make any difference to the readings.
The car is a standard Leon Cupra 240bhp.
Any help greatly appreciated.
RPM MAF in g/s
800 8 g/s
1500 15 g/s
2000 20 g/s
3000 23 g/s
4000 34 g/s
5000 43 g/s
