Water Pump Not Working
Mat
Noticed other day that when I turned the engine off, the water pump was working away like usual. It was changed dure the cambelt change.......
Could it be an issue related to the sensors that I apparently need to change
Jan 8, 2007
2,958
Wiltshire
Are you saying that the pump that normally runs when you turn the engine off is no longer working?
This is the secondary water pump IIRC, separate from the one that would have been changed with the cam belt. First thing to check is your fuses on top of the battery if that's the case.
Mat
Yup, that's what I'm saying! Is the secondary water pump not the same one as the water pump you change during a service?
Edit: re-read your response
Apr 15, 2009
2,189
Midlands
I have the same problem, havent heard mine for good few weeks
My mate told me it works similar to the radiator fan and this time of year you wont hear it much until the hotter days??
correct or crap?
Jun 17, 2007
1,032
Aberdeenshire
Mines always comes on and stays on for a while even if just switched on and off straight away,
not sure if its supposed to do that but it does.
bertrum
No dude, not the one changed in a service - the one changed is the mechanical driven one by cam belt. Secondary Water Pump is at the front of the bay, tucked under the front panel - I was taking pics of it's location at the Chesterfield Meet, although you weren't exactly paying attention :p
May 25, 2008
2,400
cambs
check that its getting voltage if not its the first fuse on the left on top of the battery, might look ok but its the contacts that burn out , this fuse controls the ... secondry w/pump,cooling fans and the aircon fan . i have bypassed mine because of this . sorry for the rant!
