Swapping ECU's both MK4 Cupra's possible?
Nov 10, 2004
1,000
Colchester, Essex
Hey folks,
This is just a quick question, I have done this on my MK3 Ibiza Cupra in the past, but is the process the same for the MK4 Cupra?
ie swapping a revo'd ECU with a stock ECU
I know you need to do the immobiliser bit in Vag Com, but other than that, is it the same as the MK3 process?
Many thanks,
Sean
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
The clocks on the mk4 are paired with the ECU, so if you change the ECU you neet to change the clocks too.
