SEAT LEON front parking sensors retrofit - VCDS errors
Jan 30, 2023
Hello dear friends,
I am following Lozzy guide
on front parking sensors retrofit. Last saturday I managed to connect all wires, install new control module and connectors just to test if it will work.
First I thought I dammaged something because of bunch of errors after starting the engine. But then I realized it was because I had to take out the battery to get wires in engine compartment.
After clearing errors caused by battery disconnecting, there are two errors remains and I do not know what is the reason. It seems to me that I need to set something in ABS settings but I can not find what or it may be the control module is not suitable for my vehicle...
I tested sensors without installing it in front bumper, just to see if it will work. They seems to be OK, there is park pilot on screen.
I would be very gratefull if someone can direct me in what way to search further to resolve this ?
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 61637000003659
Coding: 19EE629224240970877A060140C32498462490E1600224732042F074C202430000000012121212B835351919323200
Shop #: WSC 00049 770 00101
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
VCID: 78FF5EE1C3D34C8AED-802C
1 Fault Found:
8260 - Databus
U1121 00 [009] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 173719 km
Date: 2023.10.01
Time: 11:48:54
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5F0 920 751 E HW: 5F0 920 751 E
Component: KOMBI 303 0310
Coding: 07A512082390000800086A001000000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 285F4EA153F31C0ABD-807C
1 Fault Found:
16776980 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 173719 km
Date: 2023.10.01
Time: 11:48:46
Best regards,
Emir
