Seat leon 1.9tdi 57 plate
May 1, 2019
Hi iv got a seat leon the turbo kicks in now and then for a sec or two and cuts off iv changes the turbo on it,vacuum box,MAP sensor,MAF sensor,egr valve but no luck could anyone help me out with this
saveoursouls
415
234
36
Manchester
Maybe the actuator how do I sort it out ?
It’s part of the turbo so if you’ve changed turbo you’ve probably changed it..but I can’t say for sure.
If you switch the engine off and back on does the turbo come back before the issue reoccurs? Do you know what PSI the turbo is boosting up to?
