Seat Leon 1.9 TDI BXE - Engine Temperature keeps dropping
Sep 18, 2020
20
i have an issue with my Seat Leon 1.9 TDI 2008 retaining engine temperature.
I have performed an EGR delete using a blanking plate and it appears the warm up time now is now significantly slower than it was before.
Once the car reaches 90 (without the heaters on,) if I'm sat idling and then put the heaters on, the temperature starts to drop and doesn't stay at 90.
As soon as i turn the heaters off the temperature then rises back up to 90.
I have changed my thermostat to a Gates one however, i still have this issue.
Could it be the Coolant Temperature sensor that is faulty?
RADIOTWO
493
95
North Derbyshire
It will do as the cooling systems are noe very efficiant nowadays so as it shoud be
R3k1355
1,790
251
Yorkshire
There's usually an EGR cooler that takes some of the heat out of the exhaust gas before it's stuck back in the engine.
With the EGR blocked that heat isn't there, probably why you're noticing the temp dropping.
Reactions: tahir_patel1
martin j.
1,996
891
Fife
I’ve noticed with a few diesels I’ve driven that idling allows the temps to drop and using the heater wii speed this up.
20
Ah ok that kind of makes sense. Would you recommend blanking off the EGR cooler too?
smutts
372
188
The temp gauge lies anyway.
The computer sticks the dial at 90C for real coolant temperatures from about 70C to 110C ish.
Stupid really.
Try it with an OBD reader.
