removing lower part of airbox
Mar 25, 2009
1,245
bath
hey all,
just a quicky, as title says, need to remove airbox, top is easy but there is a weird bolt thing where it connects behind the battery, i have tried pulling but dont want to break it,
any info please
Ric 2001
Need an ID-ten-T form
hope this helps
Slippery_Stu
72
Once you have removed the bolt from the front right hand corner (as you look into the bonnet) the rest of the lower air box is held in place by rubber grommets/pins.
It is a little disconcerting but just give it a gentle tug with a rocking motion, it should pop out :)
Had to remove mine recently to fix the rear washer connection [:@]
Good luck....
