I am about to do some work on my Granddaughter's 11 plate and need to disconnect the Radio, and wonder if there is a code that needs to be inputted after I have put the power back on ?
Depends on what radio is there.
Some are coded to the car and don't need but the cheaper option need code.
so if is a base radio small tiny screen black and white needs code, mine was coded to the car.
if you don't know what radio, a picture will help.
ebay sell codes but they are written on the car manual in a small card
Thanks for the reply, I have been informed that since 2009 the coding is linked to the ecu,, so if its the original radio it picks up the code but if I was to put the radio into another car it would not work
I did the job on the radio, and turned back on, the display said "Learning" then started playing music !
Hi brothers i just changed the battery of my car and i had an really annoying issue with the radio, it went in safe mode and needed a code. I asked a friend who has a small service and he guide me to some online apps that he is using this one and this one, i got the code on the first one and i wanted to tell you how it has for my and how i solve it. Hope this helped
