Hi guys,
As mentioned in one of my other posts in this section, my car is not running great at the mo and im trying to source the problem/get it running to its full potential. I have just stumbled across this post which states that for the K03s conversion you also need a shield, heat deflector, push on connector, and Lambda probe, in addition to the K03s turbo.
http://www.seatcupra.net/forums/showthread.php?t=95246&highlight=mk3+part+number
The K03s was installed by the previous owner, and it wouldnt surprise me if the additional components have not been changed with the turbo, so now i just want to go through and check everything is as it should be.
Can someone verify exacly what should have been changed for the K03s conversion and how the parts differ from the stock K03 setup please? Also, is this post saying that a different lambda probe is required for K03s?
Thanks again guys,
Greg
Thanks again guys,
Greg
