OBDEleven new feature
tracktoy
425
303
Sure you are aware currently OBD11 runs two apps, one for VAG and one for all other makes.
Yesterday they released an upgrade to the all other makes and you can now scan and clear faults using the non vag app but only on Android.
It also means you Garage will now have all the VAG Vehicles as well as your non VAG ones.
tracktoy
425
303
No I am afraid personally I expect no changes to IOS for VAG motor other than small bug fixes. They are currently working on Toyota in my view and then will be looking to add more car makes but very much on the Scan and One Click App model.
The other thing to be aware off on both IOS and Android is they keep chaning the minimum supported version so make sure you update your phone or you could find yourself not being able to use the app.
  • Wow
Reactions: H Rafiq
tracktoy
425
303
I should also add that because you can access the Non VAG App looking at Seat motors you get the following feature
Again this only works on Android.
From the Garage you will see a new blue box to get info
Select the blue box and you will get the following screen
Enter you VIN Number and you will get something along the lines of the following from my car
