Lower strut brace problems
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
Hello,
iv recently hit a pothole and mangled my front lower strut brace. ordered a new one form the dealers,
when it came to fitment, i had an attempt myself but i couldnt get it off because the back of the bolt keeps spinning when i try to take it off...and it looks like its inside the subframe? :confused:
is there something im missing? i spoke to a VAG specialist and they are adamant that my car doesnt come with a lower strut brace...so took it to a local garage and they are saying i might have to take my wishbone off and even then,might still not be able to get at it. he offered to heat it up and try to reshape it, as nice as that sounds, i said i'l just leave it.
so basically i want to take the old strut brace off, and get the new one on...
any ideas guys?:help:
Faisal
May 27, 2008
1,445
Most likely at work
yeah i want to take the old one off, then fit the new one.
some reading on here suggests its simple with a few bolts to take off. even though it IS a few bolts, i cant seem to get them off since they keep spinning...
they never mentioned an airgun, id rather do it myself to save a few bob
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Remember the fixings for the lower strut brace are the boll-hoffs, and are a compression fitting and it sometimes likely that they lose grip on the back.
Grind/cut the head of the bolt off to remove the brace, then grind off the face of the boll-hoff, this will then just leave a small cylinder of metal rattling around inside the subframe which should ping out on driving.
Just get some more boll-hoffs and bingo bango!
Tried and tested, as i fudged up fitting mine.
Jimski
Faisal
May 27, 2008
1,445
Most likely at work
it seems that the bolt at the back is inside the subframe and theres no logical way of getting my hand into it without having to take everything off...looks like another stupid design along with the door seals which leak and crappy hose clips amongst other things iv noticed over the years lol
Faisal
May 27, 2008
1,445
Most likely at work
Jimski
thanks a lot mate!will give that a bash. once i f*ck up,il be back here :)
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Haha no problem dude,
Just to illustrate;
The cylinder type collar which the bolt is inside is the bollhoff, it compresses/squeezes/squashes when you fit them.
Basically yours has maybe twisted and lost its "grip", but if you lose that collar on the front, there will be no fitting left and you'll just be left with the subframe whole once again.
Jimski
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
well u could take the garages offer up and heat it up , they then attempt to undo , it breaks and job done, i had a cu nt of a bolt that i couldnt get off , oxi set'd it off and fitted new ( well my unlce did
Ronin225
4,652
22
Worcester
As jimski said it is a rivnut (Bollhoff is just manufacturers name, do lots of industrial fastners)
Need to cut head off bolts to remove brace then drill/grind off the lip that stops it falling through the hole
Tidy hole and start again with fresh parts
