ko4 fitment tip for hybrid
Jan 8, 2007
2,958
Wiltshire
If it's a CRT hybrid then it uses a K04 compressor housing IIRC so you'd need a K04 TIP, though there does seem to be some inconsistencies.
Easiest way to check is measure the diameter of the compressor inlet - any more than 45mm and you need a larger (K04) TIP
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
It *should'nt* come with the K04 comp wheel as is, but should be machined down..
K03s silicon TIP will fit over in that case.
I say *should* as they dont seem consistent..
Check with CR on the machined OD of the TIP and tell them it must be to fit 44mm max for silicon TIP to stretch over (I think) not 51mm which is from memory k04's std size and I have seen one machined to 48mm too (neither will fit an available TIP)
I dont think LCR tip fits without moving water expansion bottle.. sits every thing to high and other fittings then dont reach either without mods
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
My forge tip for k03s didnt fit... it was impossible for me to get it fit on... well done if you can do it.. but i oped for getting a silicone LCR tip from the bay
