You say you have checked the fuses ! but how did you check the fuse, and did you check the fuse specifically for the lights ? if its not the fuse then try turning the switch on, if its not that check the bulbHi just purchased mk2 leon no interior lights working at all checked all fuses still no joy
but you have not checked the bulb !Door open wont activate lights
No fuses listed for courtesy lights
If you switch on lights on panel still no joy
I have swapped all fuses just incase and there is not a fuse listed for interior lightsThen if the switch is on then its a fuse
its no use just swapping fuses as you my put a lower fuse in the wrong position, you need to test the fuse with either a fuse tester or a meterI have swapped all fuses just incase and there is not a fuse listed for interior lights
have you any power to the switch ? although that will not affect the boot, but I still think its a fuseI tested all fuses with a meter 1st off and then swapped fuses for peace of mind im no novice iv done all basic checks but your replys arnt giving me a solution or a fix if there is no fuse listed for lights is it controlled by something else ie body control module etc there is also no boot light
I have a similar issue with my 2010 facelift, any idea which fuse as I've done pretty much the same tests as this guy?try either 28 or 34
