intercooler
Cupra-cal
139
Penicuik
does anyone konw if a front mounted intercooler for a mk 4 golf 1.8t 20v would fit a leon cupra?? cheers,callum
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
which one you looking at, the forge one doesnt fit, neither does the ths offering.....
toyosports for mk4 golf should fit.
the link youve provided comes with rubber hoses which are crap..
pipes dont look beaded or edged either.. id stay away from that one, go for the toyosprts one for 40quid more and that definatly fits and comes with silicone joiners and beaded edges
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
They don't need to be beaded just use decent silicon and T bolt clamps.....Mine are not beaded and have not moved at all.
Mine pipe work was beaded at the ends but I had to cut them to make them fit, I had 2 hoses blow off, which is not fun when you are doing 125kph on the motorway, anyways I took them off again and used some cold weld epoxy to bead the ends and all has been good since(touch wood).
also I used the Toyo fmic and can't fault it thus far.
