Ibiza FR PD130 BLT injection problems
sMh
28
Hi guys! I really need some help if you can!
My Ibiza Fr has a very strage behavior at idle, when started from cold all good, no smoke, no strage sounds nothing, letting her idle for 2 to 5 min and thing go out of hand. No errors related to engine malfunctions or so.
1. Idle consuption go far down to 0.3l/h(somethimes 0.2) and 2.2, 2.8mg str(somethimes under 2mg str) injected at idle(too low)
2. Injector 4 correction incresed as engine get warmer, i've seen even 2.02 corection on injector 4 (changed yesterday with a good know injector same code BA, no difference)
3. timing belt was done 3 days ago with blocking tools, all good torsion value after tb change -0.6 0 +0.6 depends on engine temp(i've tried to play with torsion values but there was very little to non in injection department)
4. camshaft and lifters are in very good shape.
5. Temperature sensors are good I think.
first image is with a new timing belt, others image is with the old one with changed torsion values.
As you can see when cold injectors got good values.
if you have more question I'm here.
Thanks and have a nice day!!!
sMh
28
Update: Disconnected EGR, NO CEL, disconnected MAF NO CEL, map is stock so how doesnt trow a cel? Any ideeas?
sMh
28
Hi man, wow thats bad man, mine starts absolutly perfect cold/warm.
If you don't have any errors, search for cranks in fuel lines, your car doesn't have fuel for the first 2 4 seconds, so somewhere air got to your fuel system. Change all fuel lines, is cheap.
What ecu modification do you did for instant consuption? Injection duration from ASZ or AVF? Thanks! Keep in touch!
Uptade for thread, my egr MIL happend yesterday after 10km trip, waaay to late.
18
Only Software for more power if you want to send Injection from BLT stock BA code my egr is stop software with this soft and stop hardware i put it RacePipe no errors nothig. But im with 1749VB this soft is 1.62 pressure 390nM
sMh
28
But did you have symptoms like me before stage 1? 0.3 l/h and bad injector 4 readings?
And let me know if you resolve you're starting problems! Cheers!
Apr 5, 2021
18
Yes 0.3 on board computer from vac com 0.2 consumation when car is cold injector is good but when is hot two injector are 1.5 - 2 changed with other 2 and same but i driving and i dont care when check show now i replaced... So for the problem with cold start i have this problem from 3 years :D evrything i try and nothing now i show one theme and i try this is same problem when is full no problem but when is 1/4 same simptoms https://forums.tdiclub.com/index.php?threads/pd-tdis-hard-to-start-first-time-in-the-day-no-problem-thereafter-all-day.265442/
sMh
28
Did you change all fuel lines? I still think that fuel lines are cracked, or you can change T piece oi fuel filter with those 2 orings. Something it's wrong with fueling on your car. Try those things.
Apr 5, 2021
18
Yes something it's wrong... i try this in this theme. For fuel lines No change maybe i will try for last... I change with new orings and better fuel filter 30$ MAN. I try to isolate this valve and i removed and put in filter from Golf 2 but same...
Apr 5, 2021
18
but who fuel lines to change ? In motor evrything is dry no one fuel or leak or you mean to change from tank to motor ?
sMh
28
All fuel lines on engine bay, yeah they could be dry, but maybe they only catch air not leak any fuel. You could verify the lines from tank to the engine bay too, maybe they got cracked.
Anyways somewhere air got in the fuel lines thats my opinion about your problem.
You could put a see thru(transparent) hose into inlet fuel hose where the fuel goes to the engine, so you can be sure that engine is starving from fuel.
What about tandem pump? If I remember corectly you've change it no?
sMh
28
It's ok, you need to try to put transparent hose as feedline to see how much fuel you lose.
Apr 5, 2021
18
I try with transparent and 2 hose is full with fuel and when start car after 6-7 hours from unnecessary hose i see bubbles air
sMh
28
if you see air bubbles, thats the problem, you need to find where air get in the fuel system. or put a unisens valve on the feed hose and see what happens.
sMh
28
Thats very strange, if you put contact 3 4 5 times before starting the engine? Is not starting faster?
