Headlight recoding needed after module replacement - Help
Apr 7, 2024
14
My seat leon has had the headlight module replaced. I believe it needs coding or the parameters need to be changed on it using a VCDS if I am not wrong. Does anyone have any experience with a VCDS for the VWAG? I was also wanting to do other little mods using it whether a VCDS is the correct tool?
PS I do need help with recoding the parameters asap to get the headlight working. Thanks
