Hi All, i have a seat leon 2019 1.5tsi manual, engine is a goner due to a front end collisions. I have found a replacement engine complete but its from an automatic car. Engine code is DACA.
Do you know if this will cause any issues if i buy the engine from an automatic car and put into my manual?
Is there something else i need to do, i’m presuming i need to remove the flywheel off the new (automatic car engine) and put my flywheel and clutch onto it? Possibly spigot bearing?
Is there anything else that i’m missing and does anyone know if anything else will be different or should be drive/run as a manual engine fine?
Thank you
Thank you
