Door Lock Actuator
DigitalSushi
145
66
No one has exp with this ?
Would be very surprised if you don't have to. There is no other way into the centre of the door.
has a vid about taking off the door cards, you need to be real careful of connected speaker wires and use proper plastic trim tools as if you don't you are likely to damage the cards or paint
Reactions: mty12345
ile
32
Hi,
so you think that i can not replace part from outside only to remove those 2 bolts on door and 1 on chassis ?
  • Wow
Reactions: mty12345
